gomopar440
Livin' my life...one gas station at a time.
Friday I took the windshield out (mostly). It broke up as it came out and got glass everywhere. I wasn't too suprised about that though as it was completely spider webbed before I ever got the car. When it broke the glass got in the cowl, defroster ducts, under the hood, etc... basically everwhere.
BTW: The windshield frame has no rust whatsoever in the glass chanel. WooHoo! Finally, a good suprise for a change!
I had to remove some stuff to be able to take the glass out. I had to pull the upper interior trim pieces from around the roof and pillars. Rusty, check your mail box this coming week.
Saturday I had to clean out the broken glass before I could do anything else. Then I started to finish grinding all the spot welds on the floor pans. I got through about 2/3 of it before I called it a day.
Afterwards I headed out to the local second saturday car cruise in. Unfortunately it could have been called a Mustang cruise-in this weekend. There were some nice rides there though. The only Mopar I saw there was a very clean red 93-95 RT/10 Viper.
Today I finished the rest of the grinding and then coated the metal with some rust converter primer. After that dried I got to work on removing the dash. First the steering column went out. Next the dash itself. Lastly the heater box and the vent on the opposite side.
Every time I pulled something out of the car, more broken glass would come raining down. I had to keep taking breaks to use the shop vac to suck the glass shards and rust flakes up.
The wiring harness and the pedal support bracket are all that's left in there now.
My goal was to get everything out of the way that would be in the way of welding the holes in the cowl. The cowl area where the driver side vent bolts to is the worst with almost nothing left to it. I also need to make a big patch behind the brake master cylinder and where the blower motor fan sticks out. The trans tunnel has a 4" hole that needs attention as well as the bad section on top of the tunnel between the passenger footwells. I have a friend at work who is a welder and he's offered to weld everything up for me. I just need to get the metal (no problem) and make the patches. The vent area will be the hardest as it has about a 1" lip that sticks up into the the cowl to prevent water from just running down into the interior, like it does now.
I'm probably forgetting something, but that's what I get for going a few days without posting.
