Saturday was largely spent largely fighting with the shifter, as documented elsewhere, although I did finish plumbing the fuel line to the carb. Once I get the front end back down, I'll tighten up the fittings on the huge filter betwixt the tank and pump, and that'll be it for the fuel system. I was hesistant to test the fuel gauge since I'd replaced both it and the tank sender, but with a jumper from our hokey-ass ground tab to a chassis bolt and five gallons of fuel in the tank, damned if it didn't work. That was a good feeling, since that's the first time I'd ever seen this dash showing a fuel level--the old gauge had shorted long before I got the car and never worked.
I painted my throttle return-spring bracket...
Then mounted it under one of the intake bolts:
I later moved it one bolt hole back, as the throttle was pretty hard to operate with it stretched so far. If you look really closely at that picture, you can see the fuel line to the carb, way back by the alternator. It's sorta hokey-lookin' but it works and it's not against any hot engine parts.
I used my mad electrical diagnostic skills to determine why the dome light has never worked...
Easiest fix to the car thus far!
Sunday was a bit slower, because I was just simply exhausted from two almost-12-hour days outside in searing heat. I removed the clutch fork, but despite getting it onto the pivot fairly easily twice, neither time was it engaged on the throwout bearing. I really didn't have the patience to keep after it so I gave up, determined that I'd get the borescope from work to assist me in seeing what I'm doing. I practiced what I preach about thermostats, removing the parts-store junk I'd originally installed and replacing it with an NOS 180° Robertshaw.
I filled the coolant and addressed a couple of small leaks, the worst of which was at the radiator end of the lower hose. I put six quarts of oil in the pan, and noticed a tiny weep at the level-indicator tube that I need to address... not a big deal, but oil's expensive in this case and 10 quarts is a lot to lose. I swapped out the speedometer gear adapter in the trans, which was so galled to the cable nut that I broke it trying to remove the cable. No fear, I had a new cable and no shortage of adapters. After finishing, I realized I'd forgotten to install the speedo-gear clip. Ah, well, it's not like I'm done under there yet.
Tonight I went out and got a bit done despite a heat index of 99°F (actual temp 87°) after work. Out came the spark plugs so I could verify #1 TDC firing and set the fixed base timing. I reoriented the oil-pump driveshaft per the FSM and reinstalled the distributor; it should be very close to 10° BTDC at fire-up. I installed the plug wires, hiding the "MSD" printing on them the best I could and routing them through factory separators on the valve covers. I might still swap the plugs out for colder ones. I simply wasn't in the mood to get beneath the car and fill the transmission or mess with the clutch fork (and I didn't bring the borescope home anyhow). Hot is one thing, but I had my fill of hot and filthy over the weekend.
Any night with a couple more things checked off the list is a good one.
