After a whole week off--and I hated every minute of it--I was back at it Saturday with gusto.
'Twas exhaust day, and I was flying solo. I'd never done a complete exhaust, front to back, previously. Stretch had helped me a little bit with the tailpipes and resonators last week, but it was mostly up to me and yesterday Stretch had other business to which he needed to attend. Played with his deck all day, I'm told.
I'd originally purchased a complete 2½" header-back exhaust for this car from Summit Racing, but as time passed during the engine build I started to wonder if it was enough. I had a 3" X-pipe kit lying around for more than a decade (Remember the LeBaron? Me either) and had bought a set of Magnaflow 3" mufflers to use with it, figuring I could taper the pipe after the mufflers and prior to going over the axle. I also ordered a set of Jones Exhaust "Header Buddies", which are designed to not only eliminate the collector gaskets, but replace the flat collector flanges with an adjustable ball... that would give me some freedom during installation.
Except it wouldn't. The Jones parts I got were flat-out made incorrectly, as there was a straight section of pipe ahead of the ball part. That I could've overcome with grinding, however the TTi headers have their flanges welded on the inside, right at the flange--there was no way those balls were going to seal. Hopefully, they'll work for the Challenger (Hooker Darkside) headers.
As of yesterday AM, for simplicity's sake I'd decided to just bite the bullet and install the 2½" system, routed into the sides of the extension pipes that came with the headers, at a smooth angle. That would leave the open end available to install cut-out plates that could be opened up at the track. Once I got to the shop, though, I decided I had all day so I might as well futz with the X-pipe a bit. Futz I would.
Note to Nuts: If you ever walk into an exhaust shop and ask them to install a custom X-pipe, you don't get to complain about the price, period. Even with well-made parts and all the tools of the trade available to me, getting everything cut so it would align, with the X-section where I wanted it
and maximum ground clearance, took me well over an hour. The worst part was, after I was sure I'd screwed myself and cut one pipe too short, I reversed the pipes ahead of the X and it went together much more smoothly. It was still a pain, though.
It's a bit more evident in this shot that the outlets of the "X" are actually angled up toward the floor to provide more ground clearance in the rest of the system. Things would have gone much more quickly had I not cared about tucking things up as high as possible.
The extension pipes came next, requiring serious shortening where they enter the X-section. I wanted them as close as possible to the driveshaft without possibility of rubbing, to take advantage of the tunnel.
They're pretty close to the floor, but they won't hit either it or the ground. In fact, from the side of the car, they can't even be seen. These two next shots best illustrate their proximity to the floor.
All welded up and ready to continue. Though I had a rack of pipe available, I was out of the 3" that came with the X-pipe kit. This turned out to be the perfect spot to taper the exhaust down to 2½", though that certainly wasn't by my design... it just worked out that way.
I had a pair of really-nice Flowmaster tapered cones--3"ID to 2½"OD--left over from the LeBaron (Remember that car? Nor do I) so I decided to swap sizes and use parts from the Summit kit to reach the turbo mufflers they'd provided... the Magnaflows were back in their boxes at this point. Could I have used them? Possibly, but there's precious little room in the "muffler wells" and their forward end would've been perilously close to the floor had I used the tapers after them.
Of course, at this point I had real momentum going and completely forgot about the camera, other than this shot of the silliness whilst I was welding the tailpipes, which are (thankfully) 2-piece on the A-body application.
The reason I say "thankfully" in terms of the two-piece tailpipes is because they saved a ton of work. They're split directly over the axle, and of course are designed for a stock A-body. As you'll recall, I moved the springs inboard 3" on each side, so they now occupy the exact spot the tailpipes want to be. Because of where Summit's vendor split them, it was a fairly simple matter of rotating each section to get the after-axle section well outside the frame rails--far enough, in fact, to install resonators (AP 700196, 2½" ID in/out) in an attempt to further quiet the engine.
The resonator/tip hangers were highly-modified Nickson 17144 "upside down" hangers, which are similar to the standard universal hangers but have the clamp built-in and upside-down (the U-bolt faces up) so no unsightly U-bolt ends or nuts are visible. They went from this:
To this:
They're mounted using the otherwise-dormant original bolts for the leaf-spring shackle hangers.
Once I had the tailpipes finalized with maximum clearance to literally everything--brake and fuel lines, fuel tank, frame, and the drag tires--they were welded into 1-piece units. I then determined muffler location. I had to cut off a few inches of the over-axle pipes to move them back. Since this kit also fits Darts, with their 3"-longer wheelbase, there was plenty of pipe to spare. Once the mufflers were located to my liking with universal hangers at the back, I installed the pipe tapers and found two sections of the Summit system that, once cut to length, installed like it was the original design. I band-clamped the tapers to the 3" from the X-pipe, and clamped the mufflers to the tailpipes... that leaves me options for later, should I decide I want a change. I also band-clamped the resonators to the over-axle pipes for the same reason. Everything else was welded 358° (I'm sure I missed a couple of spots
Final results:
Other than the headers and the forward section of X-pipe, about which I could do exactly nothing, the exhaust is tucked up and hidden nicely... resonators and all.
Other than the fact that there are two of them, the tailpipes don't exactly scream "
high performance!" either.
Well, until you start the car anyhow. Despite four mufflers, this engine
insists on being heard:
Volume warning, as usual.
View attachment Exhaust - Nuts (mono).mp4
