It's done, starts from the key again, but I have to tell the saga of how I finally got there, should be good for a few chuckles!
Sooooooooo, first I tried to put the "spare" on without jacking up the car, twisted & turned, contorted & cursed & just could not get it to push on.
So up went the front of the car, still couldn't get in far enough, so up went the back of the car.
OK I can see, but when I get in that far I can only move one arm at a time, So now I remove the tranny linkage rod, then I managed to get it lined up but would not stay on, even tried a flat punch to tape it in, darn thing will not stay on just touch it & it falls off.
So I get the bottom section of the 2 piece unit & compare, look exactly the same, but the "spare" is hard as a rock & the other is nice flexible rubber!
OK, so I put the 2 piece lower section in, tranny rod back on & figure I'll have to splice in the plug for that into the better firewall connector!
Rock hard piece
Un-taped & ready for surgery
Soldered up & ready for shrink wrap
Just plugged in every thing up top for the test & my lord it cranked from the key!
I think I would have lost it at that point if it didn't!!!!!!!!
Now I have to reroute all the wires up top.
So it looks like I wasted my money buying those clips, not enough left to repair.
So after about 2 hours of kicking & screaming I had to do a feel good SOMETHING, anything, so I stuck on the rear plate, one step closer to hitting the streets!
And how was your day!
