K not liking this, if I put it straight it completely blocks the fuel gauge, cocked a bit I think I can see the speedo enough & peek around for fuel.
Got the wire out, ended up using the hood release cable grommet for that, speedo was even tighter.
On the other car it was over by the blank clock bezel hanging from the top of the dash, but this has a rounded bracket with only 1 screw hole in the middle &then to hide the wires I think I would pull the seat belt warning light & snake through there?
3 wires left under dash, ground no problem, use same on as radio.
Hot with key on I'm not finding.
Have 3-3 prong connectors, red is hot all the time, the orange I can't get to, it's wire tied way up top.
That should be at least for the light.
There's a yellow near the column, has a green off it that I think goes to the heater switch, but I only read 10. something volts there with key in on position?
So I come to this, do I really need a tach, it's automatic, I would be much more likely to use the kickdown if I need a surge then to downshift & go slapstick.
No intention to line up & race anyone sooo, I may just say adi os to the tach completely!
