I definitely want the pliers, but yeah--keep those brake pliers. Those things are truly miracle workers when you need 'em (I have a set). I also don't need that little spanner directly above the brake pliers, because I don't know what it fits but I know I ain't got it!
I'll take all the Vise-Grips you don't want and that green machinist's vise if it's going away too.
I have no idea what this thing is, but I feel like I should. Also, I'll bet it wasn't inexpensive. Any markings like make/model number on it? I'm curious.
Left to right, we have: Oxygen sensor socket, possibly an oddball oil-filter socket (or something HVAC related), oil filter wrench (when you tighten, the jaws close around the filter) and a 4WD or full-floater axle nut socket. I tried to figure out what that octagon socket fit and came up empty. Nothing here worth shipping in my world.
I didn't see it with the other air tools, but is this dude still available? I'm not familiar with Rodac, but the "Made in U.S.A." is promising. I have a Campbell-Hausfeld (Wal-Mart) air hammer and it's
garbage. Plus, the bit retainer is broken. I won't spend the money to get a new one for it.
In this next photo, you have old rear-brake caliper tool, used to
turn the pistons back in on GM/Ford rear disc brakes. The piston doesn't push straight in on those (or many newer vehicles) since the parking brake ratchets the caliper piston closed to lock the rear brakes. There are about 10 variations of that tool now, because (of course) everyone had to design a slightly-different way to do the exact-same thing.
The rusty dude below it is a Saginaw lock-plate removal tool for older GM (all) and Mopar (tilt only) steering columns. It's a lifesaver when you need it, but I don't think you've got anything on which it works anymore. Saginaw columns on Mopars went away around '89 on cars, somewhere in the '90s for trucks and B-vans which is also when GM finally stopped using that design as well. If you've ever seen a movie where they steal a car by slide-hammering the ignition lock out, that trick was literally for Saginaw columns.
The tool on the upper right looks like a valve-stem installer.
In the larger version of this picture, the flexible screwdriver doodads look like carb adjustment tools for non-automotive applications (motorcycle, small engine, etc.).
I don't need any of that stuff--I already have a lock-plate tool and stem installer--but at least it identifies it.
I can definitely put these two fellas to work:
Again,
if nobody else wants 'em, I'll take those bendy wrenches as well, except the bottom two. I've no idea what the second from bottom is, and I've got nothing metric on which to use the bottom one.
If anyone steps in and says they want something I've noted, give it to them. You've done more than enough for me already.
