Dr.Jass
Pastor of Muppets
I'm not too concerned about the NSS harness. I don't own anything that'll be an automatic by the time I'm done wth it.Think it's time to start another box for you, wiring, filter & belts 1st in.
Oh yea, I have another neutral safety harness , I can send that to replace the one you sent me.
This may not be something you see often in your neck of the woods, but on Dodges of that era--hell, well back to the 1990s--what is often causing a parasitic load is the underhood fuse box itself. Here in the Salternate Dimension, unbolting the fuse box and flipping it over often reveals a mess of corrosion that looks a lot like birch moss. While it's not necessarily conductive enough to cause goofy electrical gremlins, it will present enough parasitic load to kill a battery overnight. If it's still actin' funky, have them look at the underside of that fuse box. We've seen it a lot here where on warm winter days and in the spring, the salt spray rivals a Pacific cliff during a typhoon. My Dakota had that issue, but I only knew of it from seeing it several times in the shop at work on much newer trucks.So I'm hoping my 05 ram pickup battery drain down problem is finally fixed. guess I'll know in a few days, had it in for inspection & asked them to change the wiper switch on the arm & the park relay, someone steered me in that direction.
The mechanic thought on it a while & remembered that it's usually the switch in the motor that causes the parking to fail, He changed the motor first.
It was still draining down, & the battery they warranted 2 years ago was testing bad, so they tested the battery, with the cables off it was losing power over night.
Warranted it again (to my surprise because the original one would have been out by now) & hooked everything up & let it sit a few days & it started every AM.
Now in the beginning of this problem it would take a few days to a week to drain down, so I won't be sure till it sits a week or 2!
I'm hoping that one is finally solved, been going on almost 3 years.
It's by no means a Dodge-only issue, but it seems to be more common on those.
