thrashingcows
Decided today to address the cab slipping from side to side on the cab mounts. Took me a while to figure out what was going on, but that was what was happening. Annoying as all heck, almost every corner, or big bump I took it would "clunk".
I thought I would be clever and grease everything up really well when I installed the new poly mounts. Well this was one of the reasons things went haywire.
I removed one side at a time, cleaned all the grease off in the parts washer, cleaned the body side with solvent and then finally re-installed. Then snugged up the bolts. Then I measured from side to side to make sure the cab was evenly spaced on the mounts.
One thing I did find was that once I had things in place, and I tightened up the nuts, that the nuts would bottom out on the shoulder on the factory bolts. I think this was the other reason the cab was moving around on the mounts. Not tight enough to hold things in place.
So I dug through my buckets of misc washers. Found some thick hardened washers from ??? But regardless I stacked two under each nut and it gave me enough addition thread to be able to torque them up to the factory 40-60ftlbs.
All done...right this time...
