Chances are the wiring would've been fine, really. A lot of the wiring on these cars is not what an engineer would specify but can carry far more amps than one would think and do it safely. If the wire on the left is a 10 gauge, then the one on the right appears to be 14, and if it's a 12 then I'd say the one on the right is 16. There's no such thing as 10/12 gauge, it's one or the other and the difference is significant. As an example, though, my power-hog room air conditioner in the garage has 14 gauge wiring (the original cord), and methinks that draws a tad more amperage than a pair of high-beams, at 110V to boot.
As far as the DRLs, the reason you were getting the buzzing was because of how they're run. DRLs don't run at full brightness and the way the engineers did that was to
lower the voltage. Since the H4 system is designed to operate at 12V-15V, the relays probably didn't have volts enough to keep the coils engaged, causing them to flutter at high speed, which makes them buzz like that (the headlamp-door relay in the Black Bitch did the exact-same thing when the contact points in the motor were burnt). The headlamps were dimmer than normal because they were being pulse-width modulated by the fluttering relays. Suffice to say, the failure of the DRLs to function correctly was in no way a reflection on the kit itself. Blame idiotic laws and the half-assed engineering used to comply with them. :doh:
I wish you'd have asked about this prior to buying the kit. You may still be able to make the bits work, assuming it has the right parts...
So, how could you make this work? Pretty simple, really. You must use
5-pin relays and sockets, just wired a little differently. Using the standard markings on automotive Bosch-style relays, you'll want your original headlamp low-beam 12V+ run to pin
87a, which should be the center pin. Your output + wire to the headlamp bulbs should be on the pin marked "
30". Pin
87 should run to 12V+ BAT (constant) or 12V+ IGN ON, (if you don't want them to work with the key off). Pins
85 and
86 are your pull-in (trigger) coil, so they can be reversed, but one should go to ground (and probably already does) and the other, which would be your H4 trigger, should be routed off the positive wire for your
park or side-marker lamps rather than the original low-beam positive. With the headlamps off, your original low-voltage signal now comes through the relay at rest, so your DRLs work as designed. When you switch on the headlamps, the park lamps illuminate and will send a full 12V signal to the relay, which will then engage full battery voltage to the low beams. That's the easy way, and the easy way always has a drawback. In this case you won't have just a park-lamp only setting on your headlamp switch anymore. If that's a problem, simply run your trigger wire(s) to the headlamp output wire on your headlamp switch. I'm pretty sure you didn't jump this massive project without a service manual, so it should be pretty easy to determine where to tap with the factory diagram. In fact, the headlamp-switch pinout should be the same from about 1965 through 1993, if not even later.
Quick recap:
30 = Headlamp low-beam positive wire
to bulb (relay output)
87 =
12V+, either battery or ignition on (your preference)
87a = Original low-beam positive wire
from truck wiring (relay input)
85/86 = One to
ground, the other to one to
park-lamp + wire or
headlamp + at switch (this is simply an electromagnet, so polarity doesn't matter)
It must be wired exactly as described or it will not work correctly. Follow to the letter, and you've got both wicked beams and legal compliance with no silly buzzing noises or strange illumination. :dance:
Now tell me you love me.
