You have to soak the new clutches for at least 20 min in friction modifier before install, and there are 4 "thin" disc and 2 thick. The thin ones had it marked on the disc material but after soaking it had dissolved away, thankfully the two thick ones had different markings and they had not disappeared so was able to figure out which disc were which. To do it again a small paint mark or scratch on the side tabs on the thin discs would have been helpful.
Then it was just install them in the right sequence...thin clutch disc, steel, thin, steel, thick clutch disc, align cone and side gear with splines and done one side...same on other side then put two halves back together and tighten everything up. Again strapped to the vise with some wood and ratchet strap.
Then wrestle the carrier back in the housing, couple bars and a few taps from the rubber and dead blow hammer and it slid right back into place.
Refilled with 80W90 and the friction modifier and for a couple days it was a little rough...think everything was just settling in...now it's smooth as silk!
