Alright been a while since I have updated this...again!
So back in Oct/Nov 2021 I took Patches off the road and into the shop to get to a bunch of stuff done that I have been putting off for a few years now. Mainly the spring eye bushings were either toast, or the bolts had seized in the bushings and I had uneven suspension travel, or no travel at all.
First was the front springs...
I had decided I wanted to try a set of poly bushings in the front springs just to see if the ride would be noticeably harsher, or that they might last longer, but I had forgotten that I had put in a set of "smooth ride" after market springs and they had the large bushing in the front eye so the kit would only work on the rear eye of the front spring.
Well once I started pulling things apart I found that on the front eyes one side was seized, the other wallowed out. I removed the old bushings with fire and the outer casing on the bushings I used a sawzall to cut most of the way through them, then hammer and chisel to crack them loose and drive them out.
So I was in a spot with no bushings for the front eye and started looking on-line for a poly bushing. Well turns out there is no listed kit or single bushing set for the large diameter eye bushings in poly that I could find...OEM style rubber no problem!
I had a vague recollection of some large poly bushings I had bought/received/found decades past so started digging through my hoard....well I did find something and it would work with a little modification!
I had exactly two of these...what are the odds! But they were to wide to fit within the frame spring bracket so I had to take some material off the outer face...about 1/8"-3/8", but lucky me I have no belt sander so had to put on my backyard engineering hat and come up with a way to do this.
This is what I came up with...
Drywall sanding pad with some 120grit mesh then sliding the bushing back and forth...back and forth...back and forth...for what seemed hours until I got them down enough that they would slip into the bracket.
As found on the left, in the process in the middle and finished on the right...
Once they were done measured and trimmed the inner sleeve.
Then it was lube everything up and install...
New bolts with stover nuts installed as well...with lots of never seize this time round!
