Now that suspension was done it was steering box time, the output shaft seals had been leaking for over 4 years so definitely time to get this done, and since the steering coupler would be out as well I put another rebuild kit in it.
Kit I got for the output seals...
Fairly straight forward...remove snap ring, then drill a couple holes 180* apart and use 2 screws to pull the seals out...then re-install the new parts.
Then back on the truck it goes...
So next was the steering coupler...I only seem to get about 2 years out of a rebuild, even with a grease nipple installed and fresh grease pumped in at least 3-4 times a year. This time the hole for the cross shaft had wallowed out so had to toss a couple welds and hand file it down so it would be nice and snug.
And since I had a spare shock boot I thought I'd try to use it as a bit of a water/debris shield. Then it was reassemble with the new parts and the PITA of getting that damn cap locked in place...
Got everything back in the truck and started to bleed the PS system...that turned into a n off and on 2 week ordeal.
I couldn't get all the air out of the system, after what seemed like hours of turning the wheels back and forth with the motor off, and with brief fire ups to turn the wheels back and forth, with the wheels the air it still had air trapped somewhere. I figured it had to be in the steering box so I loosened the lines, turned the wheels and and heard some glurping and farting and it seemed better, tightened the lines back up and fired it up and it didn't immediately foam up so that was a good sign, came back the next day all was well!
