I had to make another post so I could attach more pics. You don't mind do you?:dance:
Time for some fluid changing. :wtf: Gotta be done since the oil and tranny fluid both look almost black and can only be told apart by smell.[smilie=f:
First the radiator got topped off with the best faucet water money could buy.
Then the oil change. No problems cept maybe adding a little too much oil. not enough to worry about though.
Now we get to the fun part, the trans fluid and filter change. Has anyone here EVER been able to get a tranny pan off without spilling at least 50% of the fluid you were trying to get INTO the drain pan all over the floor and yourself? Me neither.:doubt: That was only the beginning of the fun though. I relieved the pan of the remaining fluid, spilling half again as much as it had left in it of course.[smilie=l: I took a looksee in the pan and immediately wished I hadn't... [smilie=2: Can anyone identify what these parts may have been at one time long ago? I had a few other pieces about the same size as these but they fell in the oil drum when I emptied the fluid. My best guesstimate is they would be from something about 6" around. It was sitting in about 1/8" to 1/4" of aluminum shavings covering more than half of the bottom of the pan. :doh: At this point, I am figuring that this 904 trans is a lost cause. However, me being the optimist I am, I cleaned everything out, sanded and repainted the pan, stuck a gasket to the pan and then bolted it back up. Then I tossed a gallon of tranny fluid down the tube for good measure. The real acid test will come shortly. What do I have to lose at this point, right?[smilie=i:
While I was rolling around on the creeper I got a couple of pics of the rear sub frames where the spring relocation kit will be installed. The kit will give me more room for bigger tires and at the same time it will replace a very bad section of the pass side frame rail. If I wasn't planning on doing the relo kit I'd have to either replace the rail or cap it.
Anyway, onto the fun stuff... Hook up the battery, stick the fuel line in the gas can, clear everything outta the way and turn the key. Man I love the sound of open headers. :dance: Anyway, first issue to pop up is a hose clamp on the tranny line going into the radiator making a mess. Shut it down, tighten clamp and start 'er back up. So far so good. I was messing with the shifter to seet what kind of noises the tranny was going to make. When I pulled it out of park into neutral, I felt something shift in the car. I looked out the door and saw the rear wheels slowly turning.
If the tranny is shot I shouldn't get anything out of it I would think. I let Mark hop in and work the gas and shifter while I watched the rear tires. It would go into gear forward and reverse and shift throught at least one gear change. :hmmm: Mark even took it up to 110 on the speedo with the only visible problem being the unbalanced tires. :wtf: Maybe I got a cat tranny with nine lives or something? I won't really know how well it works until we put a load on it and see if it can actually MOVE the car. So far it looks promising though.:dance:
While the car was running the dash lights and some of the guages started working. I guess they needed the Alt hooked up or something.:huh: After we got out of the car I looked under it and saw a large puddle forming. I checked it out and found it to be dirty water. When I looked inside the car right above the puddle I found the front of the passenger side floorboard was full of water too. Apparently the heater core has now popped.:doh: I just cut the big hose and ran it to the small hose nipple on the intake and removed the hoses from the firewall. Problem solved for now until I can get a new heater core.
BTW, Here's a pic of my project for tomorrow morning. These springs have got to go! I'm going to just put the new XHD springs in the stock location until I can get the spring relocation kit installed.
That's all for now folks. I may have to wait till I get back to PR for tomorrows update post. We'll see:bravo:
