First thing I did today was pull the slowly leaking tire and check it out. I didn't find any obvious punctures so I cleaned the rim up, replaced the valve stem with a new one and remounted the tire. So far it's holding fine *knocks on wood*.
Next we got the headlight buckets bonded in (finally!:giggedy
. They really help to stiffen the front of the fenders up quite a bit.
Then I used a hammer and a block to straighten out the '70 grill center. I got it to fit well enough to work for a while as a driver. The headlight bezels required a little persuasion to stay where they are supposed to go. I'll need to rework this whole frontal area sometime in the future. For now it's the best place I could think of to put these parts for the trip back to TX.
While I was thinking about it, I removed the Go-Wing from the trunk lid. The bolts I used were either already stripped or trying to strip out. I didn't want to loose the wing on the road while hauling it back to TX. It's back inside the trunk for now.
Mark bondo'd the welds around the new quarters and sanded them down close. These will need more detailed sanding before the finish coat of paint is laid down. They look a lot better than they did before though.
I went out today and got some hood pins to keep the hood down. The T/A hood already had holes for pins from the previous owner. All I had to do was line it all up and drill some holes in the fender for the pins and attach the hood plates. Now that the pins are in it's apparent that the hood will need to be adjusted over towards the passenger side about 1/8". I get on that later as it doesn't really affect anything right now.
While I was out I picked up a trailer light to fix the one that got melted. Apparently I parked it a little too close to the burn barrel. Oops...:doh: It was just a 5 minute fix. I didn't want to let it slide and then get some cop with no sense of humor pulling me over for a faulty trailer light on my trip back.:naughty:
I wiped the bondo dust off the whole car and then put a coat of flat black over the newly sanded quarters. It looks much better now. The rest of the car was another story though. After another trip to the store I was ready to remedy that situation. Now armed with 6 more cans of flat black spray bombs, I started working my way forward. The doors just got a quick touch up since they were already flat black before. Then I did the passenger fender, the hood (top and bottom), the driver fender and the grill area. It took about 2 hours to finish the spray paint job. The results? I'll let you judge for yourself after I post the pics.
Tomorrow morning we load the engine and transmission in the back of the truck and get the Challenger on the tow dolly. Once those biggest items are taken care of, I'll go ahead and load the rest of the parts in the truck and the car. I'm hoping to hit the road no later than noon.
