When last we left our W2 340, 'twas doing its impression of George Thorogood: "I'm outdoors, y'know."
It wasn't there for long. Soon enough, SHAT showed up and we carted it off to his place. Upon arrival, we immediately set about installing the blowproof bellhousing, flywheel, and clutch. There wasn't a lot of photography happening, but you get the idea.
The block plate was temporarily installed with bolts to keep it centered during the installation of the billet-steel SFI-rated flywheel and ceramic-metallic clutch disc:
Disc thusly aligned, we the installed the 2,800lb Borg & Beck pressure plate. I was going to use a 3,400lb plate, but the guy at Ram Clutch said, "You're going to have a light switch with that disc and a 3,400lb plate. You might want to consider a 28." I said, "Cool!" and grabbed one of the two I already had.
Out came the temporary bolts, and on went the Lakewood bell. We also installed the Spectre adapter motor mounts to fit the 340 to the Slant Six K-member, which were pretty straightforward:
Ready to rock? Not quite, but ready to find its way home:
Agnes smiled.
Stretch smiled too.
Even my dog was stoked.
Agnes smiled.
Stretch smiled too.
