the tumblers the HF version...the BIG boy, ive run various media thru it with...pisspoor results so it got shelved years ago...the only good thing i found it for was floatbowl bodys, but as seen by what youve done its clearly been my media
that finex looks real similar to mine, tho id suspect mines a newwer model of some kind as its only 3-4 years old..still in the box, it was bought to do the crown vic thats on hold..it was part of my "you want this job done then your buying me these as part of the payment"
as for the eastwood mini, i use it ALOT..in fact ive used it enough to learn a few tricks with it..it likes the paint thinned a lil extra to spray nice, i use it exclusively for "tight spots, jambs, window lips and stuff like that prior to a shoot with the big boy, i also like using it on motorcycle stuff as it wastes less paint with the much narrower fan..all said ive probably run about the same amount of paint thru both of them...and the big boy laid down quite a few coats(epoxy, primer and paint) on a short bus!!!! on top of everything else its been thru
