It's not making me crazy a'tall. It's not my car.Hey Doc before I start making you crazy I want you to know that I do appreciate your knowledge & input, I have learned a lot over the years!
Think being the operative word here. In my case, I wanted to know. I didn't want to figure out later that the car was bent and potentially "oil-can" (and hence shit-can) a $600 roof panel and $8,000+ worth of bodywork fixing a tweaked chassis... or find out the car dog-tracks.Now with that said, here's the mess I made, I have it to a point that I can live with, a friend was over & we did a lot of measuring & think frame rails & shock towers are in the correct positions, the inner fender definitely is NOT.
Starting up front she's back at least 3/4"...
It isn't possible to deform one part of a welded metal structure to such a degree without deforming other component parts of said structure. I could accept that the bending at the firewall would've been taken largely by the right-angle flange to which the inner fender is welded. However, it also ripped free of the shock tower and deformed itself between spot welds, which to me is much more worrisome.
That would've been my cue to have the car straightened before proceeding. It might've saved you a bunch of effort putting them to what you think are original positions. Multiple instances of collision damage introduce the possibility of a snowball effect on the finished car. Having a car "racked" is not terribly expensive; the shop that did mine usually charges around $600-$800. I had to provide the specs from the factory BSM due to the car's age. I got lucky and was charged less, but after seeing the results--again, I can't describe what changed but even Stretch remarked that the car "looks different"--I'd have paid $1,000. It's cheap peace of mind.I think this car was hit in a few places, I ran into some funky bends in the metal in the rear... tried my best to put em back to original positions when I was welding in the trunk floor patches & installing the new drop offs
That lower gap at the inner fender/firewall joint would bother me every time I opened my hood, especially knowing I was only 56 spot welds from making it right when I had opportunity. I drilled more spot welds than that just on my drip rails, and more than three times that many for the entire roof job. Stretch and I did another 200 or so on the Valiant--a car I know was/is crashed hard and did not have straightened. It's a beater, intentionally so via the basement budget, and I simply don't care enough. I might if it's hard to align or drives wonkily.
I understand--I'm so sick of drilling spot welds and messing with W2 valvetrain I could vomit. Concerning the latter, only the thought of potentially destroying hundreds of dollars in virtually irreplaceable parts finally overcame the denial that I could make the first heads work. I'm now swapping out the heads for a factory-engineered, known-working solution--at great effort and expense. I know it's right, and any failure is on my basic mechanical skills rather than those as a wannabe engineer with a "it should be good enough" attitude.
It's your car, and as long as you're happy with it that's all that counts. If you are, then my picky ass is of no concern.
