RUSTY Cuda said:Paint stripper didn't work to good on the rough surface so the wire wheels came out again, remembered I had some coil cleaner(for my alum a/c coils) so I tried that on it, full strength even loosened up the paint, maybe a layer of aluminum too[smilie=2: a guick round with the wire wheel & a couple of 80 grit tapers for the tight spots & she's almost ready for paint!
Silver would be close enough right???(I have some laying around!)Rich.[/QUOTE]
I eather leave alone or shoot with Al and clear coat but sliver should look good.
Best wishes from this way, if its got the right pan AND a windage tray dump it in.:helpme:RUSTY Cuda said:She was running when I got her, had good oil pressure ,drove it around the yard to move it once in a while before I started rippin into her, sounded solid, a little smoke but it had been sitting for years, haven't done the compression test yet, but she's going back in as is & I'm getting out the rosary beads! Rich.
RUSTY Cuda said:.... a little smoke ....
RUSTY Cuda said:Whats a valve seal,
RUSTY Cuda said:Would they fork up just from sitting around, .
