When I got no results at 9 & 19 I was trying to see if any of the others went to that yellow wire & 20 did show up!
Yes, continuity between Cavity 20 and the large yellow wire on the ignition-switch connector is consistent for a 1974 interlock car. Cavity 20 feeds the interlock override switch.
Your test of Cavity 22 to the brown wire on the column connector is good. That's the circuit that feeds 12V+ to the coil during cranking, and you've verified that will work as designed. That connection did not change between '73 and '74.
Cavity 18 is a power feed and very hard to test accurately. as it's connected to the starter, ammeter, alternator, fusible link and about a million other things inside the car via a welded splice. It'll be wacky no matter where you test it. That position didn't change either, so don't concern yourself with it.
I was hoping to avoid dismantling the dash, & was fried after 2 hours under there today I will pull the switch tomorrow.
You only need to take it apart far enough to probe the BR wire (no tracer!) on the wiper switch's W terminal. You'll need to remove about 10 screws to do it: Six on the light bar, and four on the switch panel. The switch panel should come out, allowing you to access the back of the switch, no further disassembly required.
Poke your probe into the backside of the connector at that terminal, and check it against Cavities 9 and 19. Report back which one has continuity. I think I know the answer but I want you to verify it. The only other thing we'll need to verify to make everything work: Where does the cavity that
doesn't have continuity go? If my suspicions are correct, you've got one wire behind your dash that's either missing, cut and hanging, or goes into a connector you can't find.
Also noticed my 73 book only has one engine bay diagram & it's not even B line.
Either your book is missing pages or you've got the Body manual. There are two manuals for both 1973 and 1974: Chassis and Body. They do not repeat much information between the two, but the wiring diagrams comprise about 40 pages across both manuals; most of the useful diagrams including the stuff on which we're working is in the Chassis service manual.
Now the new harness except for the lockout should be plug & play if I'm going back to all stock parts.
"Should be" and "will be" are two very different things. If it's all stock, Cavity 19 would have continuity to a pin in the interlock connector, which is apparently missing. For the car to have started normally before, it
had to have 12V+ on Cavity 19. It most definitely did, but I was looking at the wrong side of the bulkhead to figure out how that voltage was getting there. I assumed, wrongly, that it was done behind the dash (possibly with a 1973 harness) and I got fixated on that. I'm now 100% sure it was done in the engine bay, and the voltage at 19 was a back-feed from that God-awful butchery involving a lot of yellow wires and a toggle switch.
OK another problem, my steering harness only has 7 pins
Starting at one end
1 yellow
2 black (thick)
3 blue w/w*
4 brown
5 red (thick)
6 double orange
7 black & black w/y* (both in one pin)
In that picture, I see
eight pins in your column connector, and two black wires. One black wire should have a yellow tracer and one should have a white tracer. The one with the white tracer should be on the end. Zooming in, it looks like there's a twist in that wiring right at the connector--is that making you think they both go in the same pin? They shouldn't.
I know all this diagnostic isn't a cake-walk for you, Rusty, but when all this is finished my goal is simply this:
- You connect the battery
- Nothing starts smoking or burning
- Twisting the key cranks the starter
- The engine runs
It might seem like I'm being a vicious task-master, but it's not my intent a'tall. It might be frustrating now, but it'll be far more frustrating if "first start" doesn't go as I've outlined.
I believe I know
exactly what's going on here, and how one of the previous owners made the car start normally. I think you're going to be just fine with the harness you bought, but please finish the few tasks I've asked:
- Check the W terminal (plain brown wire) at the wiper switch against 9 and 19
- Determine where the wire without continuity stops (it will be either 18BR or 18Y*)
- Verify the two black wires at the column connector are on separate pins (I think they are)
- Don't check anything else!
We'll make this plug and play, I promise. I'll probably need to send you one more part, but I'll need to modify it first. Luckily for you, I bought a '74 parts car with the interlock
intact. We're gonna make yours look intact, original, and functional, but bypass the interlock entirely. No hanging wires, no "what's supposed to be here?" and
no surgery.
I'm sorry I'm so dense, but this car is not making any sense.
You're not dense, you're just
frustrated. In your frustration, you start trying things that don't apply ("shotgunning"--although your accidental verification of Cavity 22 worked out nicely) and trying to absorb a complex system all at once, rather than one chunk at a time.
Believe me, this has generated a couple of headaches on my end. It's also torn up a ton of hours trying to figure out exactly what the hell was done (this post
alone has taken almost three). I now firmly believe I've got it nailed. The light-bulb moment was realizing a previous owner bypassed the interlock
completely in the engine compartment--something I should've noticed or realized sooner. My apologies for that. It ain't easy from 1,000 miles away.
I still want to make sure everything's electrically sound before you attempt to light 'er up. Humor me one more time, and I'll be able to both explain everything and get you what you need to finish this nightmare.
