Still no shipping notice on the exhaust system, which will probably come when I get deep into trying to put the interior back together.
So now I have some dumb questions, why? because I'm a dummy!
1st do the rear speakers go in first, the jute padding is back ordered, I have the top "plate" for lack of a better term & do they go in from the top?
2nd, I dug out the gaskets for the gas pedal & throttle cable, gas is evident, but on the cable does it go on outside or do I push it in & put the gasket inside?
3, throttle cable is just held in by tension right?
Put the pedal together, glue seems to be holding good, on the outside there was a little play it might have backed out, so I added an extra washer.
And finally when does the drivers A/C duct go in, looks like it might go under the steering column?
Oh yea shot a clear coat on the pumps!
Noticed that one hole is bigger than the other on the grounding strap that might be a hint to which end goes where. The one where it looks like the rubber was crimped in is bigger?
