Which spring did you mess with? Did you try going to 3,000RPM and check the timing there? The Mr. G spring kit instructs one to install both of their springs on an automatic car, and only replace the heavier-wire spring for a 4-speed. Even with both light springs, 2,000RPM seems rather low for "all in".We put the timing light on it and revved her up, and the advance stopped at 20* around 2000 RPM, so it seems like I've got 10* or more advance already at idle. I knew I shouldn't have messed with that spring. OTOH it fires as soon as you touch the key so I've go that going for me.
The current number for a '70 383 is VC173 per the Standard Motor Products website... so I started digging around in the OE book, based on the distributor numbers SMP lists. Most (if not all--I got bored) of 'em are Slant Six applications. Punching that number into my franchiser's Buyer's Guide, which is based on SMP's catalog information, that unit fits G, RG, LA, B, and RB depending on year--everything from the 198 to the 440. The same is true of VC187, though that picture looks right. Using our cataloguing, I came up with a VC188 based on a '74 Charger 400, which looks a lot like the VC187 though the canister is flipped in its photo.2. The NAPA part that crossed over to the vac advance number VC173 arrived today. It's for a small block.
It looks like the current part number for big block is VC-187 and VC-189 for small block.
I'm not sure what they need, but if it's just a bill of sale one could fabricate that pretty easily. "Hey, babe... how do you feel about role-playing? No, not that kind. Well, not at the moment anyhow... perhaps later. I need you to pretend you're the psycho that had the Duster and fill out some stuff." It worked on at least one car of which I'm aware and may or may not own.1. The DMV needs more paperwork, this time from the hoarder nutcase who sold me the car. Can't wait to try to get that.
I looked it up. Holley website for the kit #, then searched all the sites for it. All of them offered the kit to order, but I can do that without their help. But it doesn't matter since I didn't need any parts after all, the partial kit had everything I needed in it. I blew out the secondary shooter passage and also popped something out in two other places so it's gotta work better than it was.I'd make even odds that at least one store had it but nobody knows what it is.
The kit number we stocked was a 37-1544 "Fast Kit", which covers all square-bore mechanical-secondary carburetors but is listed as the kit for exactly none of them. The "popular" double pumpers (477x-4780, etc.) list the 37-485 as their specific kit, but the 1544 works perfectly and covers more applications.I looked it up. Holley website for the kit #, then searched all the sites for it.
The check ball beneath the discharge nozzle was probably stuck from sitting....it doesn't matter since I didn't need any parts after all, the partial kit had everything I needed in it. I blew out the secondary shooter passage and also popped something out in two other places so it's gotta work better than it was.
Your PV isn't open. That's not how they work, which I only recently discovered while consulting with those better-versed than I. Before dealing with those guys, I was sure that my sketchy vacuum meant a 6.5 was too high, so I replaced it with a 2.5. It changed exactly nothing. When I did consult them and mentioned that, I was told the PV is functionless at idle. There's not enough airspeed through various bleeds for it to do anything, unless the diaphragm is torn allowing fuel through it. I also learned that the standard described methods for choosing a power valve are all bunk (x inches less than a particular vacuum reading, be it idle or cruise). I'd have to go back and find it now, but it's totally dependent on the transition from part-throttle acceleration to the actual power circuit, the latter of which is the only time the jets do anything. At cruise, they do nada. Worry about that stuff once it's idling and driving OK.I've still got idle problems, and only 5* of vacuum so the 6.5 PV is open all the time. I sprayed it down with ether and it seemed to want to kill the motor where I expected it to speed it up, but it did have an effect.
I searched for 37-485 yesterday but just checked 37-1544 and it's "call the store to order" at Advance and Autozone, and Oreilly's says it's out of stock even for ordering.The kit number we stocked was a 37-1544 "Fast Kit", which covers all square-bore mechanical-secondary carburetors but is listed as the kit for exactly none of them. The "popular" double pumpers (477x-4780, etc.) list the 37-485 as their specific kit, but the 1544 works perfectly and covers more applications.
No ball, only the needle. That was stuck. 30 PSI wasn't enough to pop it loose, 100 PSI was. I've got old balls (in more way than one) so I can put one under the needle but I'm pretty sure it isn't needed.The check ball beneath the discharge nozzle was probably stuck from sitting.
Good info on the PV, thanks.Your PV isn't open.
The idle mixture screws actually make the car run better when they're screwed in because the primary/secondary circuits kick in. To get the idle speed fast enough, the butterflies are open too far exposing the transfer slot. I've got to take it back off and tweak the secondary butterfly adjustment so I can close the primary butterflies to cover transfer slot AND get enough air into the carb for the engine to run. There's an adjustment on the secondaries but it's been so long since I messed with a carb that I forgot until I started searching so it's gotta come back off.Do your idle mixture screws have any effect on your idle vacuum? I'll bet it's not as much as it should be, which along with the excessively-low idle vacuum would tell me it's time to pull the intake for a new gasket. If it's leaking, it'll be on the bottom side, likely directly from the lifter valley... which makes it nearly impossible to check with the ol' ether/carb spray trick.
It's tight. There's some sort of spacer on top the manifold that I probably should've replaced the bottom gasket on but I didn't remove it and just slapped a new gasket between it and the carb.Of course, check to make sure the carb is tight to the manifold. I've run across a lot of engines with loose carb fasteners in the last year... very strange. Stranger still, none were mine.
sadly your rightSad... us parts guys are a dying breed.
I've seen Holleys configured with a ball, a needle, and both. I just put them back together the way I found 'em. As long as it keeps the accelerator-pump passage from draining back to the bowl, it's fine.No ball, only the needle. That was stuck. 30 PSI wasn't enough to pop it loose, 100 PSI was.
Don't we all. See above.I've got old balls (in more way than one) so I can put one under the needle but I'm pretty sure it isn't needed.
It should not require that much throttle opening to idle. Mine would idle without exposing the transfer slots, with stupid-huge ports and a comparatively-wicked solid cam. I also managed to get almost 10" of vacuum out of it.The idle mixture screws actually make the car run better when they're screwed in because the primary/secondary circuits kick in. To get the idle speed fast enough, the butterflies are open too far exposing the transfer slot. I've got to take it back off and tweak the secondary butterfly adjustment so I can close the primary butterflies to cover transfer slot AND get enough air into the carb for the engine to run.
I don't think that's necessary for your particular combination either, but that adjustment is a pain in the ass either way. Stock up on gaskets, or get yourself one of these. It replaces your secondary accelerator-pump cam bracket and moves the secondary idle adjustment topside. Even if you never need it, it's nice to know it's there. Since my intake was leaking I can't truly say whether I need it, because the success I was able to get was achieved with it backed off completely... but of course I had a bunch of unmetered air entering the engine too. Regardless, I consider it $22 well-spent. In fact, I bought one for my 4780 and my Demon as well. 'Tis only money.I've got to take it back off and tweak the secondary butterfly adjustment so I can close the primary butterflies to cover transfer slot AND get enough air into the carb for the engine to run. There's an adjustment on the secondaries but it's been so long since I messed with a carb that I forgot until I started searching so it's gotta come back off.
The idle circuit will never work correctly with an intake leak. That was actually carved in stone on the third tablet of Commandments of the Lord Jehovah, which Moses dropped and broke.Once the idle circuit is working correctly, I expect the intake is going to need to come off for a new gasket.
Flattery will get you nowhere. Use a thin gasket and you'll never have a problem. I never did. Trying to make that pillow of a gasket with, ahem, "torque limiters" work was the worst-yet idea I've had regarding the Valiant (which is really saying something considering my decision to use experimental heads). Sad that it was a genuine Holley gasket, but it probably helps them sell a lot of baseplates--which are much more expensive.Given the choice between loose fasteners and a snapped ear on the base plate, I'll take the loose fasteners every time.
