Don't buy or use anything without a vacuum advance.
Factory distributors with the hex-shaped vacuum canister are adjustable for
rate of vacuum advance, but not
limit. The limit is stamped on the arm, but if you need more it's easy to grind the stops further back. Unless you're building something with a berserk camshaft, I'm not sure I see much value in an adjustable mechanical advance, since you should set it at 35-36° total and be done with it anyhow. The
rate at which it advances can be controlled by inexpensive springs. The car won't have any problem with 12-16° of mechanical lead at startup/idle. My car has proven it'll start and idle with nearly 4 times that amount.
I see no benefit whatsoever to roller-bearing flyweights. Clean, oiled bushings (not greased) will work perfectly for decades, and they'll stay oiled if you put a few drops of 3-n-1 oil in the wick atop the shaft once a year. The rollers will never see a full revolution as a flyweight pivot, which means not only are they completely superfluous, they'll also wear unevenly. Bearing stiction, needles eventually jamming or falling out... what's not to love?
I'll stick with my original recommendation: $20 swap-meet/wrecking-yard OE electronic, disassembled & cleaned, with lightweight spring(s) and perhaps a bit of mucking about with the vacuum canister. Unlike the gee-whiz Chinesium aftermarket bits, the OE part was designed to work for 100,000+ miles of abuse and complete neglect. They did, wonderfully.
I pulled the distributor apart and found those springs aren't so heavy in the real world. I guess the camera really does put on 5 lbs or something like that.
If anything I'd say the timing is coming all in too soon rather than not quickly enough. Eventually I'll get it back on the ground and fire it up to check the timing at idle and above to see when it quits advancing.
In real-world driving, I would bet it's not advancing
quickly enough in light-throttle acceleration, and is seriously lacking timing at cruise. The only time your mechanical curve can be perfect is at WOT. At every other throttle position (load), the engine wants more advance than the mechanical can provide at that particular RPM. Period.
It's literally the entire reason vacuum advance was invented: as a load-sensitive timing adjustment. People who think it's some kind of emissions device should stop playing with cars and crawl back under their rock until the next Stone Age dawns. Their cars suck to drive on the street anyhow.
I want a timing
map rather than just a
curve, so I've got distributorless setups for both the Challenger and Imperial's planned turbo engine.
