If your temperature gauge works and seems approximately accurate (mine actually reads exactly mid-gauge at 180° engine temp--and it was NOS) you can perform the pulse-voltage test for the ICL (limiter) at the tank wire. Same deal: ground the negative lead of your DMM and connect positive to the disconnected sender wire, looking for pulsed 12V. That would verify your wiring; if the temp gauge works chances are the limiter's OK. I'd still install the RTE limiter, personally... if the one in there fails, it's taking at least one gauge and probably the PCB with it when it goes.
The fuel sender wires are dark blue from the tank right to the gauge. The factory connector is an 8-pin rectangular job right near the driver's kick panel. It's got an extremely-short wire for the door-jamb pin switch, if memory serves. I had it disconnected during the Valiant floor/frame replacement. I'm pretty sure this is it:Yes, everything else in the dash seems to work. It seems like there's a shit ton of unplugged connectors under there, for god knows what. Radio, etc. The wiring diagram I've got is minimal at best, for example I've got two female connectors on blue wires taped together, but don't see anything about that.
Remember: While the engine/forward lamp (only where they're the same harness) and dash wiring are in the CSM, the rest of the wiring is in the body service manual. The rear wiring for your car is on page 5-81 in the '71 BSM, which is actual page 190 in the mymopar .pdf download.I looked for optional wiring (mymopar.com) but found notne. But it was free and I've already got my money's worth out of it.
It is. I definitely could've diagnosed the car more quickly than I typed it. I'm also sure it takes longer to read than it does to perform the tests described therein.Dang son, that's a lot of typing.
