I learned one thing yesterday, a speedo cable that says "fits most" will be at least a foot too long for an A-body. It also didn't come with a grommet and after 50 years the original one was rotten. At least the cable was inexpensive. The shorter cables are 2x as much. So I've got that going for me, I guess.
This is an ongoing issue with cables, and I'm not quite sure who to blame. I'm assuming you got an ATP or Pioneer, both of whom list 80" as the right cable length. I
believe we ended up using the ATP Y829 on his car, which is 60" long, but can't confirm that at the moment. The factory parts book only shows one cable for most applications: 2889783. No length is given, however the cable core package (no sheath)
is listed @ 80". I believe that needed to be cut to fit, but can't confirm it as I don't have an instruction sheet and nothing's listed in the service manual (that I could find). On the Valiant, I believe I just used a reproduction.
I still haven't put gas back in it yet, but the sending unit is reinstalled and the distributor has one of the Mr. Gasket springs in it and the right vac canister. IIRC the canister had 16 stamped in the arm.
That's a good one. While I was clearing space in the garage to get the Challenger out, I found one lying on the floor stamped "11". I think that's the same as what's in the W2 engine, but can't remember. With 35-36° total, that should put you near the low-50s at part-throttle cruise, such as highway speed. That's a good place to be. If you get spark knock at lower speed you should be able to adjust the spring tension to slow the rate a little, so that your "25MPH" vacuum isn't enough to fully overcome the tension but your 70MPH is... just one more thing to tune
if you're not happy with the immediate result.
Today is "I hope the neighbors don't have an open house scheduled" day since I've got to fire it up and set the timing, adjust the carb, etc. It's a pricy house. I can't imagine anyone would spend anywhere near their price and end up living across the street from my garage. SURPRISE!
But seriously, I'm actually pretty quiet compared to others I know.
A lot of neighbors have come and gone over the years here, but this end of the block has remained pretty consistent. New or old, my neighbors have been very tolerant of, and even spectators to, the nonsense in the garage and back yard. I've always been pretty respectful of time, though, and it's not something I'm doing constantly anyhow. There's no open-header silliness or attempts at tuning after about 8:30PM nor before 9AM. If they have something to say--and nobody has in 19 years--I'll go over and ask them to tone it down the next time their lawnmower or weedeater is running. Tit for tat, so to speak.
