It's not on the official wiring diagram.
No it doesn't...
I did notice the 12V+ wire for the
radio is red with a tracer, and it's right in that neighborhood. The radio plug has 3 wires (duh), one of which feeds the backup lamps (the 18g white). The orange is obviously for the radio's illumination. It's hard to tell exactly which wire the red/tracer wire is paired with at the blower switch from your photo. I'm guessing it's the black/tracer, which should be 12V+ as well. The wires at the switch are different colors in the FSMs: light green, dark green, and black. The diagram shows the blower switch having an integral jumper harness--'70 & '72 show the same thing. This seems to be the case in real life as well:
So, unsurprisingly, it looks as if you've discovered some more bodgery in your wiring. Parts from a different year or model? It looks vaguely E-body/truck based on the connector at your switch. Regardless, I wonder if your hanging wire was supposed to feed the OE radio power, although connecting it to the power source for an electric motor seems guaranteed to introduce noise.
Mine looked good too until I hooked the cable up and turned it. I'd probably end up in the same boat with a used one. At least I'm confident mine is in good enough working order to not fly apart. After 50 years, everything is worn out, which is why OER reproduced it. I'm not inclined to spend any more money on it at this point.
The speedo in Agnes works great, and it's a couple years older than yours. Most of them do. I doubt you'd end up with another bad one. I'm not saying you should necessarily replace it right now, but it's one of those little things that add up to dissatisfaction.
I'll bet very few guys are inclined to spend $300+ on a non-Rallye speedometer for an A-body. I expect it's the same case as the '72-up Challenger grille that Year One originally had repopped--they have a pallet of 'em they can't give away, nor can anyone else. That's a much-rarer item; the problem is that it's just
never broken (I have three good ones). My friend at AMD tells me the A-body parts have
never sold anywhere near expectations, so they have no desire nor intention to create tooling for any new parts... "Still too many of 'em out there in the fields." OER is still in the process of discovering that.
I get the frustration of "good enough" all too well. You've been working on the car all year and it just keeps revealing new issues. Apparently that's supposed to be the fun part. If it's time for the car to hit storage for the winter, maybe that's just the break you need to hit it again refreshed in spring. Some time away from the repeated frustration is probably a good thing (Agnes sat for more than a year at one point). Getting everything worked out takes time and money. There were a bunch of unexpected expenditures on my Valiant because if
everything didn't work as-designed it would bother me. I'm several decades removed from my 17-year-old "good enough" self. I'm a couple thousand over budget on a car
fully intended to be a piece of crap. But, everything functions (except the engine
) including the clutch safety switch the car shouldn't even have. Look at it this way: all the little detail shit you fix
now (meaning prior to it hitting the road,
not tomorrow afternoon) will be out of the way when you decide to address the drivetrain.
