Well for some time now I've had a driveline vibration. But within the last few weeks it was getting progressively worse. Only really happened on the highway...all other speeds the truck was nice and smooth.
I had replaced all the U-joints, and had the 2 piece driveshaft balanced a couple years ago. Only part that I didn't change at that time was the carrier bearing it looked almost new so I just went with it. So I figured the vibration now must be coming from that older carrier bearing?
So last weekend I jack the truck up and go to remove the drive driveshafts and when I start to undo the straps on the U-joint on the axle I find one is loose. And that there is a ton of slop in the U-joint!! Turned out that the vibration was more then likely that single cup having all the needle bearing pounded into goo!!!
So instead of just doing the carrier bearing, I now had to do a U-joint as well. No biggie. So I swap on the new carrier bearing...had to do a little back yard engineering to get the new one on...old one came off with the cutting wheel. And install the new U-joint and put everything back in.
Now I figured I'd be riding in an Imperial with the new carrier bearing, and U-joint....WRONG!! The vibration now is even worse then before!! It now shakes from about 30mph on up to 50mph...then kind of lessens until 60mph and then shakes like a ba$tard on up to 85+mph.
I decided to try flipping the driveshaft, and U-joint 180*...this seemed to lessen the shake by a fraction, but still really bad. And then tonight I was laying under the truck pushing, and pulling on the drive line and thought I could detect movement in the front section of the rear drive shaft. So I replaced that U-joint as well. Went for a drive and it's Still shaking horribly!!
Like I said truck was driving nice and smooth, other then at hwy speeds, when I pulled into the driveway...changed carrier bearing and rear most U-joint and now it shakes.
So I would appreciate any, and all comments, thoughts, opinions on what this might be.
