I had a couple of projects I wanted to do today...
I started by changing the fuel tank on my generator. The old one had gotten pretty rusty inside and a new one wasn't too expensive, so I ordered it. It fits the chassis just fine, and the fittings that are there are in the right places (cap, gauge, outlet) but there's no provision for the vapor vent that's on the old tank. That leaves an open air inlet to the carburetor which I'll likely just block. The larger problem is that the new outlet/petcock assembly isn't as tall, so the fuel hose is literally ¾" too short. Think I have a piece of 5/32" hose lying around? Of course not. I was hoping to have it running since it might be useful in heating/lighting the trailer as a temporary workshop in the winter. Agnes is in there so there's not a ton of room, but I need to build that carb and install it so heat and light would be helpful. Regardless, that project has stalled.
Next on the list was stabilizing the "new" fuel tank for my garage furnace, and changing the outlet on it to fix my existing line. While I was setting the tank a few weeks back, her Royal Houndness (the dog) suddenly decided to be quite affectionate and all up in my mojo. I lost my grip on the tank, and to avoid pancaking Valentine I had to quickly tilt it in the other direction... and one of the legs folded, effectively destroying its mounting bracket. Since the legs are steel pipe, I just need to weld that particular one in place to steady it. I set about to do that, then realized the amount of rust in the tank bracket. Since
Stretch has my spot blaster at the moment for his vinyl-top project, I've no good way to clean the metal to prep for welding (I am
not taking that leg back out!). With the tank as wobbly as it is, wrenching on it to change the outlet fittings seemed seriously anti-fun, so that project will await another day as well.
It's a beautiful day, so I might convert the other trailer interior fluorescent fixture to LED tubes (I did the first one in October) or maybe start hauling trash out of the garage, but it's really cold in there. Stupid insulation, working both ways.
