thrashingcows
Bought a new car trailer end of 2016, 16' with a 10K lbs GVW, done a ton of miles (15-20K miles) with it in the 4 years I have owned it and figured I should pull the drums and check everything. Got the trailer into the shop and up in the air and got things apart..
..sure enough the inner hub seals were all starting to go, some worse then others but nothing a good cleaning, a tub of bearing grease and 4 new seals won't solve.
Thought I would get the bearings and hubs all cleaned up in the old parts washer while I wait for the seals to show up, been a long time since I used it and when I turned it on it was mostly sucking air, so need a pail of solvent.
And once the trailer is back down on the wheels I need to fix/relocate the jack....hit the ground when pulling out of a parking lot last year.
