It was nearly 60° Fahrvergnugen here yesterday, so I set the valve lash on the Valiant and buttoned up the valve cover that had been off for about 10 years. I'd already done an oil/filter change on it Tuesday. It's quiet as a church mouse now--it's hard to tell it's a solid-lifter engine, actually. I also set the idle mixture on it, but it had already fouled one of its ancient plugs and is currently doing its Chevy Colorado impression on 5 cylinders.
I popped the cluster out to see if I could figure out what's happening with the non-functioning temperature and fuel gauges--just screams "voltage limiter", doesn't it?--but changing the limiter didn't bring either one to life. Of course, I don't know if that limiter was any good either. I'd already changed the temp sender and verified that it's good, but I didn't have the means to check the gauge at that instant. I'm certain the fuel gauge is just plain shot anyhow since the needle isn't visible. Previous owner said the gauge had never worked, so I'm guessing I'll need to replace it. It's '69 Valiant only, of course. :doh:
No one showed up to buy the car, so it looks like it's sticking around awhile. As if to confirm this, the master cylinder failed yesterday. :wall: The car still stops well, but the pedal sinks... and so it begins. :doubt:
