69.5CUDA
Blah Blah Blah
so...my camera ate some shots..well actualy my gopro ate some shots off the simcard from my camera....ahh well..no biggy plenty of shots to go around..but if it seems like some steps are missing.....you know why
so i added a cross brace to the dash then braced in from the point to the cross bar..the cross bar ties into the door striker posts...the dash is now strong enuf to stand on...main idea is that it will be used getting in and out of the car...dash got full stitched filled and end capped as well as the glove box door mounted..tho im thinking it needs to be sectioned down as its out of proportion and that the console is going to force my hand on it
crazy tons more stitching..door jambs doors floors fenders dash..you name it pretty much wiped me out..not a whole lot left of stitching currently..tho after weld cleanup to expose the holes(you cant run a bead of weld on sheetmetal) ill have to re-weld a bunch of it..done that once allready with alot of it in this past umm week or 2
started on the console....now...i know right now its ugly as sin unless you have the vision to see it thru....
picked up a dodge neon shifter and cables and have adapted the transaxle to take cables..so some missing shots for that..i flipped the iso crap shifter lever upside down to get it out of the floor as much as i could..made up a "turn" piviot so i can have both cables running along side the tunnel the "side to side" cable runs into the turn piviot and the then runs to the transaxle...bushings and the stud is welded to the transaxle crosmember so it will all remain simple to work on...the console itself seems crude but..it will meld into everything as planned just wait......take note i had to cut out a HUGE section of the spine i added and then re-do it to allow the shifter to drop flush to the floor....i reverse flexed the car while doing it to make sure nothing changed..and nothing did..i put the torsion bar crossmember on the lift and lifted the car till the rears lifted and the fronts had unsprung...with my weight on the back of the car and a lil bounce the fronts came off the ground..50/50 balance still intact
stitching stiching stiching
with the cables mouts all hard welded in i started wrapping up the drivers side floor pan..a few hours of hand forming and hammer work to get some of the panels made...alot of head scratching for the angles tooo
finished up the door sill plate areas filled and stitched anyway
turned my attention to the fire wall and grabbed the "original" lloyd firewall and trimmed it to fit in a new way...mind you i HAVE to use it.....it has the vin and vin plate mounts on it sooooooo its gotta go in even if it takes alot of work to make it presentable.....ive also started on the lower firewall
