This afternoon, I walked to NAPA and bought a replacement seal. The wrong seal, as it turned out. It wasn't their fault; I got some bad cross-reference information. I gave them the part number. Further research showed that number was for a Chrysler axle, but not an 8.75". Thanks, RockAuto. :doh:
On the bright side, I got home and within 15 minutes found the right seal (four of 'em, actually) stashed in the basement. Hence, I was able to continue working on the axle. I installed the LH brake assembly and axle and touched up the paint a little. After getting it everything assembled, it appears that I've got a slightly-bent RH backing plate. :doh: That's the kind of thing you'll only find once everything's put together. I'll try more gentle forms of persuasion first, but rest assured I'm not above a couple of hammer blows to try and straighten it. I'm not sure how big a problem it will be; it's not really bent that badly. Of course, it's also A-body-specific, but luckily I've got spares if I need 'em.
Then came time to install the brake lines. I went with Fine Lines stainless ones so they'll keep their incorrect appearance for years.
They needed a little tweaking to fit, but not as much as I initially thought: On A-bodies, depending on the year the distribution tee can be in one of two places. Obviously the lines are different, but the distribution block is as well. Mine is from a '72, so it's further away from the pinion centerline than earller ones. What was strange is that the tee that I took off that very axle did not fit the lines--like, not even close. I think it was a later B-/E-body tee, but I didn't bother to verify. The lines would've required mangling to install, assuming the LH one was even long enough. I didn't keep the original (?) lines to compare shape, but they were probably hand-bent to fit. Luckily, hoarding was my friend for once--I found the correct tee among my stash. I gave it a quick detailing and finished up the installation.
This bit's done for now, at least until we get it in the car to weld the perches. After the engine's had some reasonable running time, maybe 100 miles or so, I'll swap in the 4.10s... and then we begin Gigglefest. :dance:
Sorry for the dark pictures, but I still wasn't feeling well post-NAPA so I took a nap for a couple of hours. I was working outdoors and didn't finish up with the axle until after sunset.
Posed with the "strip" wheels:
Brake-tee detail:
Front quarter view:
I bolted on the rear wheels for effect. They look like steamrollers, but they're only 8.5":
Brake-tee detail:
Front quarter view:
