The chargers in the shop but as of yet no call to pick up my wheels
Got some more of the 10,000 little item list done, put a nut & bolt on that hanger, fun gettin the bolt in the frame rail, but now it's tight, also drilled the corner of the bracket & put in a sheet metal screw to keep it from turning, I set the tip slightly hi, hoping it will settle into the right place.:helpme:
got the splash shields onto the frame raile & inner fenders, cleaned up under there a bit, almost everything needs to be repainted, spray bombs just don't cut it, gotta touch up with something with hardener in it, maybe that will hold up better, even my brand new tie rods are starting to rust! I HATE RUST!!!!!!:silenced:
Put in the new door switch dome works but no key buzzer, not sure if I put that in, if
I remember its on the far(glovebox) side of the dash.
Got the front bumper back as far as the 10lb sledge would move it & tightened that down, tommorrow or thurs I'll call the headliner guy & see if sat will work, if not it won't happen till the week after mothers day:helpme:
Hopefully tomorrow pics of the wheels(on the car) will be up!:giggedy: Rich.
