OK some forward progress, thought I found the rear lights problem, I missed a ground, cleaned the paint off the nut & hooked that up but they still don't work.
On to the starting, put it in neutral & she spun from the key Yea!
put it back in park & again it spun from the key, that lever must have been a tad out of place!
Tried reverse & still no back up lights.
So I redid the spin to compression on #1, pulled up the pump shaft, had to do it a couple of times it spins quite a bit on the way in, but got it to the front drivers manifold bolt.
So I pointed the vacuum thingie to the pass. side & dropped the distributor in, rotor also pointing to the bolt.
Hmmmm, looks like the contact to the cap in on the other end, Am I 180 off
Had to go back to the book, it had 2 # 1's on it, small block said clockwise, that is also to #1
now I have to figure out the plug wires, I'll follow the book & hope I don't screw that up!
Oh yea that annoying key buzzer finally turned off after I cranked it a few times, I had actually looked under the pass side of dash to pull the wires but can't get to it anymore with heater & glove boxes in!
