None of those fit a fan clutch. They're all direct-drive blades (they bolt directly to the water pump hub, usually via a spacer).
Clutch fan blades have a much larger hole and look like this:
The large hole in the center allows the clutch's hub to pass through it. The clutch is what bolts to the water pump. The blade bolts to the clutch, not the water pump.
Here's what it looks like installed on my Valiant. That car has a very short clutch due to space limitations, but if you look closely you can see three of the four bolts holding the clutch (and pulley) to the water pump. You can also see one of the four bolts holding the blade to the clutch.
You're looking for numbers like 2863215, 2863216, and 3462149. The last number is the actual fan with which your car might've been built: HP small block, max cooling. It's 20" in diameter, so if you've got a shroud make sure it'll clear. There are later fan blades that work as well, usually much cheaper, but there's no way for me to interchange applications. The 5-blade cop/truck fan works as well as the 7-blade versions and can be had for less money. This one is the cheapest one on eBay, but make sure that bolt pattern matches up to your fan clutch before you order it.
Unfortunately, I have a lot more engines than I have fan blades so I'm not able to help you out with one.
