b-body-bob
Where were you a week ago1 out of every 3 67/9 abodys ive done front end rebuilds on has hung up 1 bar at random and had to be smackked in with a hammer
Seems like a big hassle to me but I guess once you've got it set you never mess with it again anyway.hell even my alfas require a bit of hammering and its a VERY similar setup..the differance being no adjuster bolt and something like 27 splines....you pull the LCA down to adjust your desired ride height/preload...haveing both ends splined slightly differently gives you infinite possibilitys
We torqued mine with the car sitting on ramps. On its weight is on its weight; the car doesn't know if it's on the ground or 10" from it.
Hard to say where I should start next. Probably rad & battery tray, then wiring.
