I should've been more clear: I was referring to the linkage clips, not the headers.I think that would be more frustration than just unbolting it, picking the engine up a little, and taking it out to bang on it.
Ah, OKI should've been more clear: I was referring to the linkage clips, not the headers.
That has confused me. The crank turns clockwise doesn't it? Seems like that would want to rock it toward the driver's side.As long as it's got enough clearance that the engine's tendency to rock toward the passenger's side doesn't create contact, you're probably OK.
OK that's it. Selling all my mopars and buying Chevys.In the other case, which I think was in '88, a friend and I were on pedal bikes and heard it from a block away, emanating from a rusty Cordoba. The T-bar obliterated the driver's ankle. His foot look like it was only attached by his sock.
Newton's third law, my friend. "For every action, there is an equal and opposite reaction."That has confused me. The crank turns clockwise doesn't it? Seems like that would want to rock it toward the driver's side.
Yes please. Will DM.On issue #2, if'n you only want one I'll split my cost (inc. tax) on a pair of the Moroso 62540s with you and send you the one I can't even use (I have to have the truck mount on the passenger's side). It'd be ~$27 plus UPS flat rate small box shipping.
The length is based on the part # 15375, so it's the effective length. IIRC that's what rockauto gives me as the number too, but that's a coincidence - this is just the shortest belt I had. I might have a cloth tape and if so I will measure it because it is possibly used and probably from that same old fellow's garage buy out.On the belt, is the 37.5" measurement around the outside, or is in an "effective measurement" gleaned from part-number data?
In that case, I'd just get a 7365/15365 depending on which brand you prefer. It'd only take an inch to get you off the end of the adjustment without finding the short end of the slot.The length is based on the part # 15375, so it's the effective length. IIRC that's what rockauto gives me as the number too, but that's a coincidence - this is just the shortest belt I had. I might have a cloth tape and if so I will measure it because it is possibly used and probably from that same old fellow's garage buy out.
Try moving the control arm--up, down, anything lateral you might be able to manage--with one hand while pulling forward on the bar. It might go in more easily with the strut rod disconnected.The passenger torsion bar has abundant clearance but still wants to be pounded in. I cleaned it yesterday, greased it, and it it stops about 1/2" short of where it should be. I paid attention when cleaning the sockets and I did not feel anything left in either socket, but I get to do that again tonight so we will see. I don't want to pound it in because that means it'll need pounded out if it's ever removed.
Everything is loose. IIRC it was like this when it was just the LCA hanging on it.It might go in more easily with the strut rod disconnected.
Heck I thought of that but forgot to give it a try. I'll throw my dirtys back on and give that a go right now. Back now, no help.tried flipping the bar end-for-end
What's puzzling to me here is that it slides through the rear socket without issue until it reaches the control arm. Correct me if I'm wrong here, but I assume you're sliding the whole bar through the rear socket. That's why I suggested wiggling the arm around whilst pulling on the bar. Flipping it around didn't change anything, so it's not a deformation on the bar itself and since you're installing from the rear (I assume, since I'm not aware of any other way) it really can't be the rear socket.Heck I thought of that but forgot to give it a try. I'll throw my dirtys back on and give that a go right now. Back now, no help.
