I've been juggling advance/retard on the timing chain and making sure the marks are lined up - at this point I couldn't tell you exactly what the open close is. This is madness. I gave up when I moved the crank cog to the Advance mark, which should have made the number smaller. It got larger.
It makes no sense to me - the lift measurement is bang on, ditto for TDC, but still the ICL is off by a large amount.
I've been all day doing the same thing over and over then checking a book, the web, paperwork that came with the cam and degree wheel, hoping I'd have an a-ha moment and see what I'm doing wrong. But that ain't happening. I'm doing it right but still something is going wrong.
I'm going to try again tomorrow. Maybe.
One thing I don't like at all is the hinky extension on the indicator that I have to use. It's threaded but doesn't thread into the indicator so it can kind of flop around. I've felt a "click" and the indicator jumps about .001 - I think that is caused by the extension self-aligning with the indicator.
Whatever it is that's wrong is consistent - I wouldn't expect that if the extension was causing the problem.
FWIW I'm indicating off the top edge of the lifter, with the mag base on the deck between cyls 1 & 3.
I've been measuring .050 before and after max. Not sure if that matters, so long as I measure the same lift on both side of max, it should still work out since I'm trying to find the center between two points.
