b-body-bob
I separated the engine from all the unnecessary parts.
The trans has been rebuilt as per the oversized tailshaft gasket. The TC looks like a reman too, it's kind of gray in color with a yellow number stamped on the engine side. I haven't pulled it out or looked at it closely. The fluid was red, smelled about like it should, but there seems to be a lot of crap in the pan, none of it shiny that i noticed. Finally, a 904 trans is a tiny little thing. The pan seemed barely an inch deep.
The engine is stripped down to the intake and things that prevent other things from falling inside the block (VCs, OP sender, etc). There was one VC gasket tab left, and it has blue paint on it. I only paid attention to one side's valves - where I had good vis, the other side was in shadow - the #7 valve looked to have light rust on it from those dumb headers, #3 had oil vis on it - maybe a valve seal, #1 & 5 looked about normal. None of the plugs were fouled, I would've put them right back in if I was just checking them. It was full of oil but the filter had very little in it. When I pulled the PS pump, that opened up a coolant drain. I caught it and it's not rusty.
Gina says to power-wash it and bolt it in.
Tonight I'll take a shop vac to it and figure out where to put the 440 until I'm done with the engine stand it's on.
