b-body-bob
Case
Cheetah
Coan
Cheetah
Coan
If I do this I'll buy a kit. I don't have time or patience to try several things that don't work before giving upif you pickup a used hyd master...which can be had CHEEP, and the rebuilds for em are cheep too..you can save atleast 100$ right off the hop...i assume the best way to do it from there is a hard line to a softline then into a hyd throwout bearing..unless theres some kind of slave setup that works
whatever you do...stay the fuck away from the "plastic cup" masters.."eventualy" they will leak and start a fire
From what I've read the way to make a 4-speed work with Shumachers is to cut the collector off and relocate it.another thought..is to take a solid look at the headers..maybe you can fab up a 2 piece Z bar that goes THRU the headers...hell ive even seen some wacky truck z bars that had been cut apart and a big U shape added to them to clear shit
This is all for the Duster, right? I like the protection of the Lakewood bell, but man it's a pain. If you plan on using it, let me know before you start. There's at least one thing you should do that I didn't think of until after it was installed, and I can't do it without pulling it.4-speed w/ Lakewood
Factory bell
Fork
It's had the length adjusted
I've had a Lakewood in two b-bodies - they're not bad at all in one of those. I understand you have to bash the pinch weld flat on an a-body so I'm not planning on using it. The 64 bellhousing shouldn't make any difference since I'll be using a hydraulic throwout if this happens. I might need to shop around more if I was planning to use the z-bar.This is all for the Duster, right? I like the protection of the Lakewood bell, but man it's a pain. If you plan on using it, let me know before you start. There's at least one thing you should do that I didn't think of until after it was installed, and I can't do it without pulling it.
That cast-iron bell is 1964 only big-block B-body, in case you weren't aware.
The forks are easily gotten new. I don't think I'd screw around with hacked-together junk like that.
No pinchweld bashing required unless your car suddenly becomes about 7 years older. The blowproof fits fine in my car, but the starter's an absolute bitch to install/service--my suggestion was to weld a nut to the bell to install a lower stud, which would simplify things greatly. We also spent a lot of time making sure it was centered to the crankshaft considering the RPM that engine will likely see.I understand you have to bash the pinch weld flat on an a-body so I'm not planning on using it. The 64 bellhousing shouldn't make any difference since I'll be using a hydraulic throwout if this happens. I might need to shop around more if I was planning to use the z-bar.
You do realize those are the dimensions of the box in which they're delivered, right?Dimensions for a 2265 mount
Product Dimensions 5.1 x 4.1 x 3.4 inches
the TD part crosses to a 602266
5.6 x 4.3 x 3.7 inches
According to that they're essentially the same other than the studs/bolts aren't offset on the 2265
I did not know that. Boy ain't that useful info.You do realize those are the dimensions of the box in which they're delivered, right?
Well, you've got fairly generous slots at the bases on the K-member. Ain't no federal law what says you can't slot the mount brackets as well (I looked, there isn't). Just back up the nut with a beefy washer. Also, if the truck mount has less offset to the studs, it might be a self-solving problem.Picturing it in my mind I'm wondering using a thicker mount could result in the holes not lining up between the biscuit and everything else. Adding a spacer is going to move the top bolt/stud up.
That's a good point.if the truck mount has less offset to the studs, it might be a self-solving problem.
IIRC the kit I bought uses the same biscuit on both sides, which was originally for the right side of a /6 pickup truck.the Trans-Dapt Slant-to-LA mounts really are is a pair of factory-style brackets using a truck mount on the passenger's side.
