b-body-bob
Yeah I need photos of my car for it to make sense, but those photos did help. I'll take some photos later to help with the following explanation.
One big difference I see in your photos is that the header is full width on the Duster and bolts to a tab welded to the fender. The one posted in the reference thread has the same thing. The one on your Valiant is a lot smaller and would be conveniently out of the way.
There are two pieces on either end of the grille that that are in your photo "Detail of RH headlamp area, upper", bolted to the fender with a stud/nut. There's no way I've found to slip those under the full width header without the the grille hitting the valence and even then they're not fully under the header.
Maybe they cut those top brackets off since they don't seem to be necessary if the grille is screwed to the header. But nobody mentioned that and it seems like it would be an important point to make.
At the bottom, there are tabs on the valence in position for those mounting brackets, but they are just tabs, no holes or anything. So there's nothing there to swap over, and its more likely I will need to drill holes in the valence to bolt the grille to, which is kinda sorta mentioned "mounted the bottom with a small bolt in each side to the lower valance."
I agree the orange/red car does look like the grille sticks out at the bottom. On the other car, one photo does show that it leans back at the bottom, or at least it seems to.
The headlight bucket attaches to the grille at the bottom so it seems like tilting the grille the wrong way would throw the whole thing out of alignment.
But where did he find a header that hasn't been stamped out for a hood latch?
Full disclosure, I may use a 'glass hood with a 6-pack scoop. It's OK if you hate it though
Dude with no hood latch doesn't need one.
Classic Industries lists a repop for $70. I ain't paying that. I've already got too much $$ in this grille I may end up just hanging on the wall.There are two NOS grille emblems on eBay right now: one's in the US @ $175 and the one in Venezuela can be had for $140.
