thrashingcows
I also just got a new (really good used) rear slider put in. This truck has an odd ball back window...it's about 1 1/2" shorter then 90% of the other dodge trucks out there. And there doesn't seem to be any rhyme or reason to when this smaller back window was used. I've seen the smaller back window used form the mid 70's on up into the 90's...randomly.
Anyway I scored this "new" one out of a 80 dodge ram in the wreckers....$35...Thank you very much!!! Needed to do a little work on one of the sliders since the plastic spacers on the bottom were gone...little back yard engineering and it's good to go again. I then took it down and had the glass tinted. This is an aftermarket unit, the original was leaking like a sieve since the joint was in the bottom drip rail...what engineering morron decided that was a good place to put a joint!! Anyway the new one has it's seams mid point on the outer left and right sides....much better location!!
Here it is before....
And after....
And after....
