OK I'm going to post all this in one thread so others can follow from start to finish in one place.
Here's a rehash of my other thread...Aug 17/10
Quote:
I worked a bit over the weekend on getting the frame built for my 2nd gen 40/20/40 seat.
With me being 6'8" and 275lbs I wanted the seat as low as possible and set back to give me lots of leg room. I have read almost every thread I could find here on the DTR related to this subject, and decided, especially after I got my seat, that I wasn't going to use the factory 2nd gen seat tracks and brackets.
So I spent a fair amount of time trying to figure out what I wanted to do. Eventually I decide that I would do away with the dual tracks and make a solid bench seat style set-up. I also decided that I wanted to use that factory bench seat tracks.
I then took all the measurements from the 2nd gen seat, pulled the stock bench out, but took tons of measurement, and then spent some time with a pen and paper drawing up several different ideas on how to attack the situation.
I decide that I would build the frame out of 1" square tubing, 1/8th wall, but wasn't sure exactly how things would work out in real life, since ideas and drawing can't always predict everything. So I came to the decision that I would build the frame, initially, from wood since it's cheap and easy to work with. So out came the table saw, and some 2x2's I had around, and I ripped me a bunch of 1"x1" wood. I then started cutting and then used my finishing nailer to piece it all together.
So after a few hours I think I have a final design, I had to modify it several times from my original drawings and ideas, the tranny tunnel for the transfer case posed the biggest problem.
Here are some current pics of the project....
Now I just need to build it from steel. Will update when I get it built and the new seat installed.
