Some more progress.
Taking the rules to the letter which state "stock bumpers, mounted with stock mounts in stock location." Doesn't state I can't
modify said bumper mounts.
They all came apart to my surprise.
Drilled holes, drained the oil and cut them down with the sawzall.
Slid them back into the outer bumper shock housing and welded it together, much stronger and safer.
The header panel will not be going back on as I have special plans for that but I wanted the bumpers to sit closer to the body and this was the easiest way.
Rules allow this cross bar so I'm installing them and welding the bumper shock plates to the tubes and then welding the plates to the end of the frame rail with some small beads.
Even though the rules forbid any pipe or reinforcement ahead of the front firewall or behind the rear firewall I am making a small rear hoop with forward facing frame rail angle braces to protect my fuel cell, safety first! :dance: I have yet to cut it to fit against the tail panel and weld it in.
Here are the plates for the cage.
The rear is two layers of 1/4" steel.
The front is two layers of 3/16" steel. I have sheet metal floor patching to do before these go down.
I also have some small 3/16" steel plates to go on the bottom of the rockers where the pipe comes through.
Gotta finish this yet also.
I got your book Stretch, wonderful read. I was quite proud of myself when they showed the exact same way of mounting a roll cage in a unibody car as what I have done with my car. I guess I have a better grasp of this then I had originally thought.
Most of the chassis tips and setup tricks in the book are illegal for my class the physic principals about the car's handling characteristics with different setups are still the same and are going to be very helpful.
Thank You!
