So I finally received my torsion bar bushings from
www.polybushings.com and set about trying to take apart the old torsion bar mounts to replace the bushings last weekend.
Got one apart intact, things are looking good.
Second one not so much.
So I decided to just make two replacement inner bushing sleeves using the one undamaged one as a guide.
Got a piece of water pipe and got a friend of mine to take it to work and machine down either end.
So now this past weekend I set about the fabrication process yet again.
Cut to fit and reused the factory end washers and welded them in place.
Pressed the sway bar mount onto the end, drilled the retaining bolt hole and then pinched the two metal halves together and tack welded them.
One completed torsion bar mount. I did replace the pivot bushings with the poly ones as well but they went in so easy I forgot to take pictures. :doh:
Torsion bars installed, K-frame installed, UCA's and spindles installed.
Next weekend.
Steering box, pitman arm, idler arm, 11.75" rotors, bearings, seals, pads, pin type calipers, 11/16" inner tie rods, 11/16" outer tie rods and 11/16" tie rod sleeves.
