who says snow wheels should just be ugly?
the wheels were free with some well worn blizzaks on 2 of em, i ran em "ugly" last year and the year before for the 2 weeks or so of "threats" of snow...we just dont see snow much out here...but theres times when its better to be safe than sorry
the wheels themselves are 15inch scion wheels..the blizzaks are on their last stretch..should be good for another seasons or 2 depending on how much mileage they get..fronts are brand new hankooks both sets are 195/60/15s
anyway i tossed the wheels in my blasting cabinet and stripped em to raw steel, then i set to welding in 3 threaded inserts on the bead...after that a coat of epoxy primer, 2 coats of high build primer, a day of sanding, then a base coat of omni to body match topped with glamor clear..all the same stuff i used on the spoiler so...new new money spent on anything but the 2 new tires and a new set of chrome lug nuts to finish the look, im looking at getting some "trailer" bearing caps for the centers..aperantly theres a set that fit or so i found on a random post on a scion board also added chrome metal valve stems
litteraly baked the primer the day before turkey..and laid the base clear turkey day....these babys are FRESH
"summer" with fresh new rubber too...LOVE the 195/60/14 quadracs AMAZING tire on the car...grippy in all conditions glued down like a gokart..and while i can feel the need for the rear sway, the car still feels very "dialed" in ..tire size and a lil offset will net you big gains sometimes.. on such a light lil car....185s SUCK anyway
"snows"
2 looks same wheels
these salt flat discs were from the lloyd, and well they are not in the greatest of shape anymore, so i sanded them up and clear coated em, they arnt cherry but as snow wheel covers and a "test" to see how well they work in day to day use, they are good enough..and this is why i added the 3 threaded studs on each wheel
sadly the lighting with everything on the car SUCKED..but what do you expect in winter?
FWIW the salt flat discs require alot of...adjustment...to get them to stop making noises, which i actualy preplanned for with nylon spacers that fit over the threaded studs...even still i had to "tweak" the discs as well..seems the biggest issue is disc to wheel chatter....the other issue is when little rocks find their way in thru the holes in the wheels and cant get out.....yes delivering i see gravel roads now n then..sooooooits kinda an issue
this is a great test for me tho on the discs for the lloyd to see what kind of things i need to pre-do to not have issues..like for the lloyd ill need to add a rubber ring behind the disc to stop the chatter due to being recessed on an aluminum wheel vs the yaris steel...ill also need to shave either the wheel or the disc for a little more clearance as its a VERY snug fit on the lloyd, lastly ill need to see about maybe a screen? on the holes in the wheels....i dont forsee gravel in my future but rocks on roads happens especialy early spring
