69.5CUDA
Blah Blah Blah
i totaly get the gamble bit, its the sole reason weve stuck with the "90 series" for over 40 years LOL, those frontloader setups have and always will spook me
i assume you run your own dedicated routing pc at the main port entering the home not some off the shelf or....gulp...isp unit...something running like pfsense?
heres something i built last last year to replace the previous closet unit as the old bastard was failing in small ways, but also wasnt up to the giga...it was also used, old used re-used and was spent....the new one is all new
for those of you who want to understand the whatfors and whys...and never pay for an ISP device again....as well as the false outages hey create....read this
www.pcgamer.com
i did a TON of work re-building the livingroom, including the closet which got a built in, but i made a cut in hidden back wall that houses ALL incoming cables from the outside world, cable, phone, cat, and even fiber, with the addition of a full 12x4 slot into the attic at the top of the wall for feeding anything new
should..for some reason any service call for ANY company REQUIRE a tech to come out...there is ZERO reason to step beyond the front door PERIOD
the livingroom when we redid the floors recieved a plethora of cabling, on both main walls, 2 hdmi 2 cat6, 2 subs, 7.1+2 surround cabling, 2 rgb+rl cables, rca cables, 1 coax, with the simple idea that any part of or partial to the system could be run from/thru to the other wall
anyway heres the closet and new router...there are 6 "switchs" thruout the house handling a wifi net as well as splitting the need for more drops
on a side note...pfsense is so user friendly..its stupid but its also VERY nice to be able to pull up event logs and know exactly what and where things are happening...and should the net go down for some reason you can reboot remotely but more often than not you can have a poke at it and see what the problem is...think having OBDII on your router and being able to go..yup theres the problem
I built my own super router out of old PC parts and I've never felt so powerful
It's easier than you think to build a router that's way better than what you can buy off the shelf.
