I've been working in the garage for about a month now, trying to squeeze 10lbs of stuff into a 5lb bag. I finally installed a new 36" walk-through door to replace the original 20-year-old 32" interior door they installed when the garage was built. It was so rotten you could sneeze a hole in it. I came up with a couple of interesting storage solutions for the small garage, though. Bike and ladder hooks are your friends.
First I did a general organization, then tried to figure out what to do with the really pesky stuff, like the Challenger exhaust, which ended up over my bench:
Staying with that theme, I decided it was time to get the unoccupied engine stands out of the way, since they take up so much floor space:
The Challenger doors presented a problem, since they can't be laid flat nor is it a good idea to set them on any of the outside edges of the panel since it bends easy. Looking around at what I had on hand, I came up with this simple solution to get them out of the way safely...
One 8-foot 2x6 with three small braces cut from a 2x4:
Mounted to the wall with decking screws:
Screw heavy-duty lag-thread eyebolt into the studs above and below your 2x6 and dangle the ratchet part of two ratchet straps from the top:
Hook the long end of the straps to the bottom eyelets, set the flat part of the bottom of the door on your "shelf", and ratchet the doors snugly against the wall, being mindful of the window-crank shafts and inner handles:
If you happen to have the shipping box for a '74 Challenger roof lying around, it makes a good buffer zone. I'd feel better if it didn't still have a roof in it...
Snug and safe where no evil can become them for the time being... and when I'm done with the shelf, I still have a 2x6 that's perfectly suited for any other use I might have. :dance:
