slooooooooow going..its bloody cold outside
i finished chipping out all of the tar/floor coating and have started trimming back the last remaining 10% of fat on the car..cleaned her out vac'd the shop floor and cleaned some welds...... by the time im done the ONLY way to lose any weight on the car will be to make the body out of carbon fiber(fiberglass panels would weigh as much or more than the very THIN steel), use poly carb for windows, carbon fiber di-dion tube(read rearend at 1500$+), aluminum drive shaft, and almost unobtainable aluminum lower control arms.....odds are ill end up with poly carb windows anyway due to costs and i need to swap the wheels out for a set of 13lb mag/alu hybrids that ive got.......some figures ive been seeing put me in a fairly safe zone and in fact leaves me with a slight possibility of actually going under my target weight of 1800lbs fueled and ready..i may actually end up closer to the 1600 mark but i think thats wishful thinking :toot:
im cheating on some of the body/cage tubing..anything thats just a "tie" bar between non critical areas is using .065-.095 tubing partly to save a little weight but also most ppl wouldn't need/want to even put these braces in...i want them!..like the supports for the rear shock towers down to the outer frame rails...the actual cage will be .095-.120 which is to spec with nhra/imca and every local track be it oval, road, or drag
ignore the tube in the center of the car...i have 1/4 of frame flex without it as ive not finished tieing a few things..so i put it in to make sure everything stayed straight and true....even still 1/4 inch without the body fully hard mounted and a cage not installed is doing pretty damn good imo
