Well, despite lack of updates, we've been moving right along on the Signet. There was much more to this than expected, and though it's not been terribly difficult it has been time-consuming. Lots of little details that you don't consider when taking on a project like this. Panels that need to be repaired or fabricated, areas that could use a little shoring up, finding things you didn't know needed attention, and trying to do it all right while actually learning how to do it in the first place. It's not a matter of trying to make it pretty restoration-wise--if it were, I'd have ordered more sheetmetal--so much as making sure everything is strong and safe. This could turn out to be a pretty serious car when all's said and done, so things like an evaporated front-passenger seatbelt mount need to be carefully considered and rebuilt. The question we've asked each other time and again during all this work has been, "Will this survive a near-5,000RPM clutch dump on sticky tires, and the potential bad landing?" Strength is of the utmost concern right now, so that it won't be later.
At this moment, both the framerail and the driver's side pan are completely done, including the "sub-floor" area of the over-axle pan (it underlaps the floorpan). I fabri-cobbled a gusset for the outside of the LH inner fender to strengthen its connection to the framerail in the area of the clutch countershaft bracket, which wasn't 100% necessary but is now 100% overkill strength-wise. An overkill reinforcement was also made for the shock-tower area just above the axis of the upper control-arm bushings, this one on the engine side. The RH rocker is also done, having been about 50% reconstructed with new metal including the aforementioned seat-belt mounting nut plate, which is now "fish-plated" and almost certainly stronger than original being double- and even triple-wall section in places. Stretchy did a fantastic job patching the sub-floor area on the RH side yesterday, and I installed the manual-trans tunnel extension for the shifter. Body-wise, we only need to trim the tunnel to meet the RH (passenger) floorpan and do a bit of finish grinding, and the RH pan will be ready to drop in place. Other than a few touches here and there for added strength, and a little work at the shackle area of the rear LH rail, that will conclude the "body" portion of the build.
Mechanically, there are now more pedals than we had at the outset and the control arms and K-H disc spindles are now installed with new bushings and ball joints throughout. The driver's side has also got the rotor and caliper in place, which we did A) because we could and B) because we needed the inspiration. The steering linkage is all new except (obviously) the drag link, and I've got the now-floor-shift column ready to go back together with the longer manual steering shaft. Obviously, the drag link will be hung only tightly enough to steer the car while pushing for the time being, since later on it will need to be removed again to pass through both the headers and the oil pan. :dance:
I've currently got the cluster out to fix a broken trace on the circuit board going to the cluster regulator, which explains the non-functioning temp gauge. It would also explain the inoperable fuel gauge, if'n said gauge even has a needle. Neither one of us can actually tell with the cluster assembled, but I've got a replacement gauge here so it's really a non-issue. I also have a fancy new solid-state cluster regulator here somewhere for it. Does the car deserve it? Not really, but it's one less concern. Regarding other electrical upgrades, I'll be installing a hidden DPDT switch in the car that will be used to change the function of the steering wheel's horn ring from its normal function to engaging the line lock. When the line lock is active rather than the horn, one of the fender-mount turn signal indicators will be illuminate as a status indicator, and when the lock is actually holding the brake the other one will light. A couple of Hugh Jass diodes will prevent backfeed to any of the other lamps on the car.
I still need to button up the engine, including degreeing the Hugh Jass camshaft and measuring for pushrods. That means I've got to remove two of those enormous fuckin' valvesprings, which is not something I'm eager to do. I also need to assemble a four-speed, which involves taking apart two A833s to create one. I'm installing an early ball & trunion six-banger gearset with the deeper 3.09:1 first gear into a '68 slip-yoke case/tailshaft housing. With that gearset and 4.10s in the rear, first gear final drive is 12.67:1--the equivalent of a 4.76:1 axle gear with the original 1968 2.66:1 first gear, or a 5.13 with the '70-up 2.45:1 first (or an A727/A904). Yeah, traction will be a concern on the skinny Hoosiers with that big hit on the last yellow. Which reminds me, I need to order a driveshaft as well... Oy.
The rear axle is almost ready to go together, Stretch having pressed new bearings and seals onto the shafts awhile back, and my having the brakes ready to install. I want to swap a clutch-type diff into one of my 4.10 center sections and put in the new "aggressive" clutches I've got sitting on the shelf. That'll be the "track pig" while a 3.23 should suffice for street duty when the time comes, especially with the deep first. Once that's together and we've got a driveshaft, we'll install everything loosely on the Super Stocks, set the pinion angle, and weld the new perches in place.
God, there's still so much work to do. As is usually the case, the original timeframe was essentially impossible. I'd hoped to have this thing at the track opener on May 6th. :doh:
There are so many pictures at this point, trying to catch up in photos is nigh-on impossible while I've still got things to do. However, a few teasers of real, visible progress are at least in order.
Finalizing the burn-in on the framerail, 04/15/17. The bearing splitter/nut/washer arrangement actually held the rail in perfect alignment axially, while also holding the shock tower to the inner fender for final welding. It worked even more brilliantly than we'd hoped.
Yours truly welding in the LH floorpan, 05/14/17. The fit of the AMD panels is really hard to beat.
All welded and ground, with preliminary epoxy primer, 05/20/17.
Same day, no time to waste. Stretchy gets after the RH floorpan's spot welds. Check out that forward rust hole, the approximate center of which was once the anchor point for the front passenger's seat belt. The one a foot back ain't any prettier, of course.
Passenger-side rear sub-floor area of the over-axle pan. Ugh.
It took some significant cutting on 05/21/17 to finally reach solid, useful metal on that rocker and sub-floor. Shitty cell-phone pic, my apologies. I forgot my camera that day. :doh:
We had to assemble this later that day for motivational purposes. It's really quite motivational.
Stretchy gets on wit' his own bad self working out one of the final pieces to building the Six Million Dollar rocker (actual cost, about $4) 05/28/17. We discussed and agreed on the approach and implementation, but the execution was all him. He went all perfectionist here (completely unnecessarily on this rig) and the results are both pretty and incredibly strong.
Toldja! This was prior to final grinding. I totally trust my life to this mount, though for obvious reasons I never hope I have to do so.
More to come...
