I started messing with the closed-chamber heads last night, just to gauge what parts are needed to get them up and running. It got ugly pretty quickly.
I checked my installed height using the old steel retainers from the heads currently on the engine. I can't use those, because it turns out a 1.460" OD valve spring does not exist anywhere the recommended spring rate of 566lb/in or greater. I need retainers similar to what's currently on the engine (1.550" diameter). That's OK because I already own those and they're titanium. The problem is I no longer have access to the retainer measurements. I ordered them by specification five years ago. The records thereof are long gone, and I can't remember if I got extra offset for greater installed height, which was a huge issue with the too-short valves. The installed height of the new heads is ~1.850" (varies a little per valve).
If my existing retainers are standard, I could theoretically shim the valve springs in the old heads .060" to get near their recommended installed height of 1.800". I have to pressure-test them, since they've been installed at a much-lower height for several years. If they don't check out, they're about $150 to replace.
If the retainers are offset, I either find different retainers or step into the world of truly-expensive valve springs. The cheapest ones I've found at a greater installed height are over $350. It's a financial wash between those and new Ti retainers.
There's only one way to find out: I've gotta pull one of the heads and disassemble one valve. But I'm learning: before I do any disassembly on the engine, I'm going to set up one of the closed-chamber heads with checking springs and my intended rocker gear to figure out pushrod clearance on a different block. I'll use the roller cam that came out of the engine. If they clear--or can be made to--with that monster's additional .082" intake/,102" exhaust lift, I'll move forward. If not it's on to Plan B, which currently doesn't exist but may involve a cam change, re-valving the existing heads, or seeing exactly how much cam my Econos can take. The engine they were on had a .528" lift solid, so my only concern is coil bind. For the moment I just need them to run, not race.
As an aside, I'd forgotten how much I hate shopping for valve springs. I also discovered that my math was off; over-the-nose (max lift) pressure on my current springs is 596lb. Weeeeee!
